charging system
Old Nov 14, 2006 | 10:29 PM
MY84CAMARO06's Avatar
charging system
i bought a new battery,,and still my battery kept going dead..so i bought a new battery..still could not charge..i tested the altenator it was good..then the battery it was good.then a guy told me to check the wire that goes from the ignition to the altenator.he said the wire should have volts.he said it was called the number 2 pin off the alt.well no power to that wire from the ignition.,.so he told me to wire that wire from the altenator to the battery..well it worked..is it going to shorten my altenator life and battery life? what should i do to fix it completly..and without that wire hooked up my choke light stays on when i hook it up it goes away>
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jwade88
Jun 14, 2015 09:38 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
dylan1303
May 22, 2015 12:24 PM
