which cam should i use
Old Jul 28, 2009 | 10:54 PM
bwarren337's Avatar
I have a 1999 Camaro Z28 with 88,000 miles about to put in an Ls6 manifold and ported throttle body, I have an SSRA, Slp lid, K&N Filter, also have 3" long tube headers with 3" pipe going to 3" cutout. front 18x9.5" rear 19x10" tires...
my question is what kind of cam would you recommend? I was kinda thinking the MS3 or something similar to that... if cam was to be swapped what else would yall recommend to replace?
Old Jul 28, 2009 | 11:18 PM
Kraest's Avatar
Retired
Futral Motorsports F13 or F14. The high-lift versions run awesome if you don't plan on doing milled heads .
Old Jul 29, 2009 | 07:57 AM
bwarren337's Avatar
wha tkind of HP could I expect from an F13 or F14
Old Jul 29, 2009 | 11:42 AM
johnny6's Avatar
Look at his signature:
1998 Z28 M6 F14HL Cam 415/395 12.24@116.15
Old Jul 29, 2009 | 12:23 PM
bwarren337's Avatar
would I need to replace timing chain, oil pump or water pump while im doing the swap..
Old Jul 29, 2009 | 01:31 PM
johnny6's Avatar
Definitely change the timing chain, no need to change waterpump unless you are having issues with it. I do recommend changing the oil pump since you have 88k miles.
Old Jul 29, 2009 | 05:05 PM
Kraest's Avatar
Retired
On any LS1 cam-swap, it is highly suggested that you replace the oil pump with an LS6 or ported LS1 pump and the timing set with an LS2 set or something similar. Also, upgrade the pushrods, springs, retainers, locks, etc.
Mike
Old Jul 29, 2009 | 05:06 PM
Kraest's Avatar
Retired
Also, the H/C/I Vette also had an FMS camshaft (F-15) (not suggested for a daily driver)
I'd get the F-14 HL again. Awesome driveability and insane power/midrange. The car felt like it was on nitrous all the time.
Vids of the F14-HL car:
Mike
Old Jul 29, 2009 | 05:47 PM
johnny6's Avatar
Don't lie, you miss having an LS1 don't you?
Old Jul 29, 2009 | 09:33 PM
Kraest's Avatar
Retired
Definitely miss the raw power.
M3 FTW.
Old Aug 1, 2009 | 07:53 PM
bwarren337's Avatar
would rocker arms be suggested as well.
Old Aug 1, 2009 | 10:18 PM
johnny6's Avatar
Nope, stockers are good.
Old Aug 2, 2009 | 09:35 AM
bwarren337's Avatar
would putting a 160 degree thermostat on help any?
Old Aug 2, 2009 | 11:46 AM
Kraest's Avatar
Retired
Nope. Just get the fans turned on early when you get the tune.
Old Aug 2, 2009 | 10:50 PM
bwarren337's Avatar
are used cams bad to use or would you suggest getting a new cam
