Maff issues
Old Apr 14, 2009 | 10:48 AM
hotrod18_69's Avatar
Maff issues
Ok here whats going on. Working on a 98 T/A Now for some reason the maff does not work at all, codes are throwing and on my Tech 2 is doesn't move. I swapped maffs for working one and no difference. It has 5 volts to the plug, signal wire from the plug to the ECU is good, and soo is the ground. I don't know what i am missing here.
Now here is the weird part. If i have the key on engine off, and pull up my tech 2 and look at the TSP %. Ok now as soon as i touch the gas and hit 1% the LTFT bank 1 goes from 0 to +25 with the engine off?? How is the possible? lol
Anyone have a logical explanation for that one.
Old Apr 14, 2009 | 12:10 PM
2001NBMZ28's Avatar
If it's P0102 I'd check the engine sensor fuse.
Old Apr 14, 2009 | 02:05 PM
Thanks, i'll check that when i get home.
Old Apr 14, 2009 | 07:05 PM
Ok it was the P0102 code, checked the fuse and it was blow. Replaced and the maff is fixed now.
But i have still having the LTFT issues. I will even go to +25 when running in cell 22
At idle its fine at 0 on cold start up and in cell 20. I haven't check it after its warmed up yet. Getting ready too.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Kyle@CSS
Jan 12, 2008 07:25 AM
