coolant smell
Old May 23, 2009 | 06:41 AM
rreale's Avatar
coolant smell
I changed the coolant for the first time, 1 month ago. Since then, after using the car, i notice the smell of hot coolant. I can find no leaks under the hood, the garage floor is dry, I haven't had to add any. I don't notice the smell in the car when the heater is on. its usually when i exit the car and walk past the front end.
The car has never been overheated and the temp. gauge is within normal range when i drive it.
Old May 24, 2009 | 10:27 AM
johnny6's Avatar
Sounds like it's just fumes coming out from the radiator cap, mine does the same thing when it's really hot outside.
Old May 24, 2009 | 12:23 PM
budgetlt1's Avatar
i've recently seen several very slow lwater pump leaks on ls1's i work at a gm dealer. it's probably due to the hot weather you may want to get it checked out-or right after you've driven it, look on bottom side of wp housing, you should see some residue if its leaking. it is a very slow leak and will only do so while you're driving so the coolant level probably won't drop. good luck
Old May 24, 2009 | 03:51 PM
eanhl2004's Avatar
Well I just had my spark plugs changed as well as a bunch of other stuff and while the front end was apart they found a lose bolt on the water pump and fluid was low...I NEVER saw any fluid on the ground and a long time I too smelled radiator fluid but saw nothing. I think with heat and a small water pump leak at running you will never see any signs...
Check your pump bolts for tight... after your next drive of 30+ minutes check the entire front end for any signs immediately...jack it up and get under and look....take a high power light and look all over above... and always keep an eye on your temperature gauge...
Old May 25, 2009 | 09:06 AM
Kraest's Avatar
Retired
Either that or your optispark drank it all.
Old May 31, 2009 | 05:52 AM
rreale's Avatar
not seeing anything under the water pump, after 10 mile drive on the highway. the smell is stronger on the water pump and radiator cap side. is it possible that the radiator cap could be causing it? if so should i just replace it.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
