Removing Oil Filler Neck
I do?...........then how come the filler piece came out intact, no broken pieces off whatsoever?
All that breaks off is that little plastic tab. If you didn't know about it, you wouldn't know that it was missing. Remove the filler neck again and inspect both the neck and the valve cover. You'll see where the tab should go.
Trust me it broke off. I bet the filler neck is now much easier to remove than the last time too
Hard to tell in the photo but I fully inspected the oil filler neck and there is no broken tab..........there is a "thread" on the neck where it mated with a "thread" on the valve cover.........where the Metco oil filler neck and breather I put in to replace the factory one I took off
squarehead
Nov 21, 2014 08:02 PM
