need info w/ engine swap>>>
I'm planning on swapping a ls2 engine w/ a th400 transmission on a 1995 camaro, what parts would i need for the engine to fit and the transmission. all help will be appreciated. thanks.
-Geoff
the 8.8 hybrid has been done several times. you take the 8.8 chunk and weld on the 10bolt axle tubes, have new axles made, weld up the TA mount and you are good to go, granted that is a way over simplified explanation but that is the cliff notes version.
stock gauge cluster will not work so you will need aftermarket gauages.
be prepared to do alot of wiring.
Th400 will 'bolt up' to the LS2, minus a couple of bolts, you will either need a TC built for the LS style crank or run a "regular" TH400 TC and get a crank spacer.
There are some other little things but it can be done.
