What is the pcv ground strap for
After chasing my high-rev-gremlin, i discovered that this ground was also causing my vacuum leak. The metal piece that attaches to the rubber boot around that pcv valve, was sort of slicing the boot open. I discovered this after fiddling around the boot and feeling some oil oozing out of the spot where the metal connects to the boot. I just slid it out and unbolted it. Then wrapped the boot with some rubber tabe. No more Vacuum leak.
Thank goodness for this forum. I was worried about having removed it. Not anymore.
autoxr166
Sep 25, 2015 04:21 PM
