Spark plug heat shields.
Old Aug 15, 2009 | 04:15 PM
johnny6's Avatar
Are they necessary? I now have a multiple cyl missfire issue (P0300) and i never did reinstall those heat shields after the heads and cam swap, just wondering if they can cause spark plug issues if not installed. As far as the missfire issue goes, i thought it was my o2 sensors so i disconnected the harness so it could run open loop and the missfire is nowhere near as bad but still very noticeable, what do you guys think? I hate that damn code it could be anything, i could shoot a video if needed.
Update: Missfire seems to decrease at WOT but drives like crap below 3000rpm.
Old Aug 16, 2009 | 10:08 AM
super83Z's Avatar
Are the boots melted at all? I didn't put mine on when I put my MSD wires on and I have no problems. What cylinders are misfiring? Have you tried to move the coil packs around to see if the problems follow the coils?
Old Aug 17, 2009 | 06:35 AM
AL SS590 M6's Avatar
Moderator
Check your coolant temp sensor.
Old Aug 19, 2009 | 06:42 PM
johnny6's Avatar
I got owned by that sensor
I forgot to check this thread, i ended up changing all the plugs and wires, and o2 sensors before realizing that the coolant temp sensor somehow came off Oh well it needed a good tune up anyway missfire is gone.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
