LS1/LT1 engine swap.....help
I'm putting a 1999 LS1 w/trans into a 1995 Z-28.If anybody has done a swap like this and can help me with information/parts for this type of swap i could really use the help.Thanks.
I'm need to know if the motor mts are different,will the 93-97 harness work with the existing ls eng(i have the ls eng harness as well as the ecm),but i want the gauges to work properly.I had been told this will drop in on the existing k-member,yet in jegs they list different k-members for 93-97/98-02 f-bodys.It's stuff like this that i need to confirm.
You need the LS harness modified to work with the LT1 gauges... and I would recommend using the LS K-member, Steering shaft, & Rack n pinion. It will make life easier but if you don't want to you can use you LT K-member and just use adapter plates to get the motor to bolt up correctly.
...try ls1tech theres alof of info on this.
JasonD
Aug 23, 2010 03:14 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
