bad MAF and MAP
Old Jun 10, 2009 | 11:59 AM
Altekameraden's Avatar
bad MAF and MAP
2002 ws6-m6 open headers
Ok i am throwing P0300, which could be caused by P0101,P0102,and P0106. Have had this random misfire for 5 days ( went through 2 in. puddle of water and it all started) I already replaced plugs, wires, and o2 sensors. Just replaced the MAF and it is still misfiring horribly. Hoping that the MAP could cause such a severe misfire of all cylinders
Old Jun 11, 2009 | 05:52 AM
Ok replaced the MAP sensor, still misfiring, and its an act of god to rev above 3,000. My only other options are crank position sensor wires are grounding out or got wet. Is it possible for the the timing gears to be off ( after a puddle of water)? Valve seals are fine not burning oil, hope I didnt bend multiple valves.
Old Jun 11, 2009 | 05:21 PM
WhiteHawk's Avatar
You have one of those super sucker ram airs? Try unplugging the MAF and driving it real eazy. Tell if you have a bad MAF or not.
-Geoff
Old Jun 24, 2009 | 12:10 PM
Alan's Avatar
Sounds like a coil pack
Old Jul 2, 2009 | 12:14 PM
Ended up being bent # 8 intake/exhaust valves, # 6 Intake valve with broken spring. My header gasket had water between it and head, so theory is water traveled through either the headers, or got by the gasket into #6 and 8. Thanks everyone. Hope
Old Jul 3, 2009 | 06:36 AM
AL SS590 M6's Avatar
Moderator
Doing what? Water in the cylinder will not break valve springs.
Old Jul 3, 2009 | 09:36 AM
I was running open headers that day, trying to get off the road before rain got worse, hit a puddle, and the madness started. Pulled the cover and saw the spring on the 0 psi cylinder. top coil of spring just separated by an inch. The valve was bent also, more severe than the other 2 valves.
HectorM52
Jul 30, 2017 11:46 AM
1996LT1Z28
Apr 22, 2015 07:56 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
