just got a ls1
Old Jul 21, 2009 | 12:15 AM
z28camaro1090's Avatar
just got a ls1
finally just got a 1998 ls1.. 115k on the clock.. and i had the rear rebuilt got 3.73s put in it..
cant wait to see what she will do at the track mods in sig what do you guys think it will do ?
Old Jul 21, 2009 | 07:10 AM
Kraest's Avatar
Retired
13.30s-13.40s with decent tires. The summertime isn't a great time to try to get good track numbers.
High 13s/14.0s if you spin.
Mike
Old Jul 21, 2009 | 09:19 AM
Marc 85Z28's Avatar
Put a stock MAF back in. Take it to Cecil in a month or two and you may see very low 13s.
Old Jul 21, 2009 | 06:58 PM
everyone is telling me to put the stock unit back in which i dont have .. whats so bad about the slp?
Old Jul 22, 2009 | 08:51 AM
Marc 85Z28's Avatar
The SLP MAF slows your car down and causes drivability problems.
Old Jul 23, 2009 | 03:45 PM
jrm1493's Avatar
I also concur with putting a stock MAF back in. When I bought my car it had some kind of non-stock ported/descreened maf and I would get lean codes when it was cold out (I guess due to the fact that the PCM was untuned and all the extra volume that was ported out of the MAF was allowing unmetered air in).
I got a stock on off gmpartsdirect.com. Kinda annoying to have to buy it but no more lean codes. I think all an aftermarket MAF does is trick the stock program into running lean which gives you a bit more power but thats a redneck way to make power. The right way would be to tune the PCM to run a bit leaner with more advance so you have full control over the process.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
