Misfire only hot??????????????
Old May 20, 2009 | 04:27 PM
bostonjim's Avatar
I have a customer's 1998 camaro with a 350, ls-1.
it is misfiring on #4 only when at operating temp.
SO FAR is did a compression test cold ...ok
changed the spark plug and wire...
swapped the injector and coil with #2 and still has a misfire ,
only #4...
cold it's does not skip, and runs great COLD.
no ticking or smoking.
Any idea's
Please welcome!!!
Old May 21, 2009 | 06:55 AM
AL SS590 M6's Avatar
Moderator
Bad lifter??? It could be a short in the injector harness or coil harness. Trace them back and see if there's a suspicious spot on either.
Old May 21, 2009 | 07:05 AM
Kraest's Avatar
Retired
It's actually a 346 LS1
Yeah, sounds like a problem with the wiring harness or a bigger mechanical problem like Al said. Pull the valvecovers and take a peek.
Old Jun 5, 2009 | 04:29 PM
Robert 98's Avatar
Possibly the #4 Coil its self I've seen coils work fine until the get hot, swap the # 4 coil with another of the coils and see if the problem moves to that cylinder
Old Jun 5, 2009 | 04:30 PM
Robert 98's Avatar
oops sorry I didn't see that you had already done that!
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
damnyankee36
Sep 9, 2015 07:06 PM
