Wierd Noise ... Need advice
Old Aug 17, 2009 | 06:24 PM
silver02camaro's Avatar
I have a 01 SS stock ls1 with headers back exhaust. Went on vacation this weekend and while I was gone it started making a wierd noise comming from the driver side closer to the firewall. The noise is hard to describe it kind of sounds like a belt squeak with a light ping. While accelerating you can hear it but once you get to a cruising speed it no longer does it. What could this be? Thanks for any advice.
Old Aug 17, 2009 | 08:05 PM
Kraest's Avatar
Retired
Hard to say without seeing/hearing it. I wouldn't be too concerned if you haven't really modded the car internally. Get it scanned for codes/code history.
Old Aug 18, 2009 | 07:03 AM
AL SS590 M6's Avatar
Moderator
Sounds like it might be an exhaust leak.
Old Aug 18, 2009 | 05:35 PM
Wierd Noise
I know its not a exhaust leak I have already checked that. It almost sounds like a bird chirping belt squeak bad gas ping all together I know your laughing but not sure how else to describe it. Any other thoughts would be greatly appreciated.
Old Aug 19, 2009 | 07:18 AM
johnny6's Avatar
Could be some very minor detonation, what grade fuel are you using?
Old Aug 19, 2009 | 03:17 PM
im running mid grade in it for now until i get some more work done to it. My neighbor listened to it he says he thinks it might be a loose valve.
Old Aug 19, 2009 | 10:02 PM
Kraest's Avatar
Retired
These cars are premium fuel only. Bad idea running mid grade in it with 10.2:1 compression and headers/exhaust.
Probably audible detonation.
Old Aug 20, 2009 | 07:56 AM
Chrome383Z's Avatar
Valves hitting pistons can make a "squeaking" sound, but I HIGHLY doubt it is that with stock valvetrain/cam...
Probably detonation as listed above...
Old Aug 20, 2009 | 10:09 AM
johnny6's Avatar
I made the mistake once of using regular unleaded, it seriously sounded like it was about to blow never again.
Old Aug 24, 2009 | 03:34 PM
steelerfan's Avatar
I would stick with premium too.Thought I was ok with mid-grade cause I don't usually get on it too hard but the ping showed up on a steep hill.Could also be the belt squeeking as well.Mine did that so I replaced it with a Goodyear gatorback & it went away
jayblev95
Sep 26, 2015 09:44 PM
MDZ28
11
Sep 24, 2015 09:15 AM
rideordie
Sep 7, 2015 08:22 AM
GT what?
Jul 14, 2015 10:17 PM
