Camaro SS 1998 code too lean
Old Aug 17, 2009 | 08:32 AM
bus106's Avatar
HI do you think the probleme are the fuel pump , the fuel regulator, .Man i lost around 10 mph on a 1/4 miles, I change the knock sensor, the mass air flow, my plugs look goods too, i think i gonna change my fuel pump and i see after the result! i have a k&n complete kit (air filter,and the cai) the car run normal but less power, the check engine light are not open but the code flash around 2 time per summer , I need help
Old Aug 17, 2009 | 08:59 AM
jimih941's Avatar
try running sea foam to clean lines and injectors, change fuel filter. Check fuel pressure, then take a look at the pump
Old Aug 17, 2009 | 04:03 PM
bus106's Avatar
Yeah but maybe something else for 10 mph on 1/4 miles are around 90 hp lost...
Old Aug 17, 2009 | 08:09 PM
Kraest's Avatar
Retired
Could very well be a fuel filter problem. Get the codes scanned and see what's in the history.
10 mph is a TON unless you're comparing it to winter times at 0 DA compared to 2000+ DA in the summer. The summer heat/humidity can cost you upwards of 5 mph.
Old Aug 18, 2009 | 05:27 PM
bus106's Avatar
sorry not a comparaison of winter/summer because the winter here i got around 10 feet of snow
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 5, 2014 11:42 AM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
Klypto
Jul 19, 2002 07:25 AM
