Exhaust Backfire issues
Old Jul 7, 2009 | 01:08 PM
SteveSS01's Avatar
I have a 2001 SS, LS1, with SLP bolt-on rear tube exhaust. Ever since installation I have had an exhaust backfire condition during low RPM acceleration, and a slight rough idle. Most backfiring occurs when engine is cold and weather is cool/ cold...I have no diagnostic readings from my analyzer, but have intermittent exhaust backfire, during acceleration, mostly during cool weather....Hot weather (I live in Pensacola, FL) has little to no backfiring issues, only when engine is cool while warming up...Backfiring doesn't occur when RPM's are raised or when decelerating.
Any suggestions would be extremly appreciated!!
Old Jul 8, 2009 | 07:10 AM
Kraest's Avatar
Retired
Adding the exhaust probably amplified (by volume alone) the situation you already had, but didn't realize. Adding bolt-ons like exhaust isn't going to make a car run any differently.
Try cleaning your MAF or filter.
Has the car ever been tuned?
Old Jul 8, 2009 | 07:20 AM
AL SS590 M6's Avatar
Moderator
Check plugs and plug wires.
Old Jul 9, 2009 | 02:19 PM
SteveSS01's Avatar
Have replaced air filter several times, along with replacing the fuel filter....Have not replaced the plugs and wires...Will replace and see if that clears it up...
Thanks!
armedtrigger
Feb 24, 2015 08:30 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jan 5, 2015 07:14 PM
