Ls1 2 ls2 swap
Old Apr 18, 2009 | 05:36 PM
SPEEDWAY726's Avatar
Ls1 2 ls2 swap
Is it possible to replace a ls1 in a 99 camaro with a 2004 pont gto engine and trans. What about ring gear on crank any help..
Old Apr 19, 2009 | 11:30 AM
Marc 85Z28's Avatar
2004 GTO engine is an LS1. Only the very late build 2005 and later LSx engines have the different crank reluctor wheel.
Old Apr 19, 2009 | 02:51 PM
How can i determin it is an ls1 for absolutely sure! I BELIEVE IT IS A 6.0 LS2 BUT NOT A HUNDRED % SURE! IT CAME FROM A SALVAGE YARD BUT NOW IM NOT SURE OF ITS YEAR.... PLEASE HELP WITH ANY ADVICE...
Old Apr 19, 2009 | 05:49 PM
Marc 85Z28's Avatar
If the engine is still in the car, look at the cylinder head casting number. Its located just below the valve cover rail at the front of the passenger head, near the oil filler. 241 is an LS1 head, and 799 (rare) or more likely 243 would be an LS2.
The rear of the block will have either a 5.7 (LS1), or 6.0 (LS2) cast into it.
The LS1 will have the camshaft position sensor at the rear of the block next to the oil pressure sending unit. The LS2 will have the cam sensor in the timing cover.
Finally, the GTO had the engine type displayed on the throttle body. LS1 throttle body is cable driven. ALL LS2 throttle bodies are electronic.
2004 GTO got the LS1, 2005 and 2006 GTO got the LS2.
Old Apr 19, 2009 | 08:13 PM
Ls1 ???????????????
On the gto engine it cam with a 90mm cable driven throttle body, wont know what the #s are till tommorow. Are all ls2 deffinitley electronic....
Old Apr 20, 2009 | 07:16 AM
Kraest's Avatar
Retired
Yes. The TB uses a motor and the computer to tell it how far to open it instead of a cable like the F-body LS1s, however, that's both on the LS1 and LS2 GTO cars, so seeing a motorized TB doesn't guarantee that it's an LS2.
Old Apr 20, 2009 | 03:13 PM
Marc 85Z28's Avatar
Ummm... I'm pretty certain that the LS1 GTO uses a cable throttle body. The only LS1 to receive an electronic throttle body was the Corvette.
And to SPEEDWAYZ26: You say it has a 90mm cable throttle body?? You may want to double check that. GM never made a 90mm cable throttle body. All 90mm TBs are electronic. There are however, aftermarket 90mm cable throttle bodies available.
Old Apr 20, 2009 | 03:32 PM
JakeRobb's Avatar
Super Moderator
I think putting an electronic-throttle LS2 in a '99 Camaro would be more trouble than it's worth.
Are you replacing a blown engine, or just looking to upgrade to something more powerful?
Old Apr 26, 2009 | 05:17 PM
danhr's Avatar
location of knock sensors.....
side of block = ls2
under intake = ls1
easiest way to determine the difference. even let's you weed out the hard to find ls2 iron blocks from the lq4's.
Old Apr 26, 2009 | 08:44 PM
Marc 85Z28's Avatar
side of block = ls2
under intake = ls1
ALL LS2s are aluminum. Perhaps you mean LQ9?
Old Apr 26, 2009 | 10:47 PM
Kraest's Avatar
Retired
I had a 04 GTO. Nope.. i don't believe so.
Old Apr 27, 2009 | 07:39 AM
Marc 85Z28's Avatar
2004 LS1 GTOs came with a cable driven throttle body.
Old Apr 27, 2009 | 03:49 PM
Kraest's Avatar
Retired
Considering that it was my wife's car and I didn't mod it.. you're probably right.
Old May 9, 2009 | 11:52 PM
97z28/m6's Avatar
the 04's a a weird set up as it does have a cable but its connected to a motor off to the side in the engine bay and is controlled by the computer. it is not connect directly to the throttle pedal.
Old May 10, 2009 | 01:30 PM
Bayer-Z28's Avatar
05-06 Pontiac GTO LS2 Vin - U
the 8th # of the Vin...
And Check the RPO codes for LS2..
