Won't stay running.
Won't stay running.
Is it pretty common for the car not to stay running in park with a stock stall and bad coolant temp sensor? I can keep it going with the pedal but when i let off it's either a hit or miss, sometimes it'll stay running and other times it'll die, when it dies it takes about 15 seconds of constant cranking to get it going again. BTW this is right after my heads and cam swap with no tune and 2 minutes of driving time, i'm getting the TC installed tomorrow and i'm also replacing the coolant sensor. Just wondering if this is something i should be worried about.
He went and got a new sensor and ran 10s on spray the rest of the day.
Another thing I should probably consider is the size of the cam, and the car is also running very rich.Another thing I noticed is the engine likes to bounce from 400rpm or so to 1100rpm I think the correct term is "hunting". It will usually do this for a few seconds and eventually die but sometimes it'll hang in there and idle for a while.
Ever broke one Mike? I was at the track with a friend when he broke the plug in on his. If I stood and held the wire so it would contact the motor would start and run fine. Pull the wire and the car would barely run.
Maybe I was thinking of the wrong sensor....
The coolant temp sensor doesn't throw a low coolant light.It's already got a small hole in the TB, i'll drill a slightly bigger one to see how much that helps. I pulled the transmission out this afternoon, tomorrow the stall is going in.
I didn't even think of the low coolant sensor because they only used them on 98-99 LS1 cars (his sig says 01) then dumped them because they're so flakey.
Don't drill the throttle body! The car just needs a tune. The table that sets the amount of idle airflow is based solely on coolant temp. The car is probably going to a default air level which isn't enough for your bigger cam. Just fixing the coolant temp sensor might help, but you really need to give it more air from the IAC, which is a tune.
-Geoff
-Geoff
all you need is an idle adjust. wut size is your cam, if it is a 236/236 then you require an idle of 850 rpm, and every 5-7 degrees or so after that it is another 50 rpm. after that you should swap your o2 sensors for a lean burn so the fuel will burn rich when idle and drop off just under 12.8 or so above 2500 rpm, that way you get a good clean idle and awsome rpm after 3000 rpm
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
