View Full Version : Drivetrain
- Opinions on my scenario?
- Occasional Grind
- "thump thump thump" is the sound from under my car
- Need a flywheel ---- Need opinions
- transmission question
- Toner Ring for Eaton Carrier?
- Rear seal question
- T-5 slave cylinder
- Slave Installation - NEED Help ASAP
- Transmission Clutch Master/Slave removal
- Well poop!!!
- Which Gears?
- lt1 throwout bearing
- Chatter problem
- not trans mount or t/a bushing
- 02 ,v8 with auto trans
- High pressure line on 4l60e?
- Hard thud when accelerating; possible bad differential
- Does this converter hub wear pattern look like a worn pump bushing?
- need suggestions for a new transmission
- Differential cover
- how do you get the clutch fork on throwout bearing? lt1 t56
- Need help with a "CE" engine code for 302
- Running out of RPM in 4th gear at the track. Shift into 5th? Or different gears?
- swapping in hurst short throw
- WS6 stores short shift stick vs Speed Inc's
- 700r4
- Lt1 T56 throwout bearing pushed in?? Please help!
- my borrowed time ran out
- Installing short shifter info needed.
- can't get into reverse
- Well, it's time to start over...Any help?
- clutch help needed
- 4.11 gears or not
- Stock Flywheel Question
- What is the BEST LT1 clutch for street/strip?
- Limited Slip Differential Fluid
- McLeod 500 Series Clutch, Reverse Hub Assy?
- fresh built 4l60e power expectancy
- tq converter or gears
- T56 help and info needed
- "Super-matic" 4L70-E, any information on this new tranny?
- throwout bearing bad???
- Need help withTransmission Lines
- 700r4 transmission governor gear help
- transmission cooler
- when to upgrade rear end?
- Easy to change tail shaft bushing??
- Help me plan my next rebuild
- Performabuilt Holiday Giveaway is back get it free. Maybe?
- Tranny rebuild kit/shift kits...
- rear end part help
- Time to start thinking about a new clutch.
- no first gear on 4L60E. 2nd , 3rd, and 4th work. reverse works . Any idea....
- anyone use f1 racing clutch and flywheel?
- How much play is normal in the rear-end
- Is there an A4 to M6 swap kit available anywhere for a 2002?
- transmission vibration and poor gas mileage
- How much play in the rear-end???
- 4L60 (93 Z28) Tail Shaft Question
- How do you remove your axle housing on a 96 Camaro?
- LS7/ LS2 clutch in an LS1?
- So frustrated. Spider gear pin bolt is stripped. Tried everything.
- From Cahall Performance Transmissions
- Could I have the wrong engine mounts?
- no 1st gear
- differential type differences?
- Newbie question - throwout bearing rattle?
- Tranny Issues after new engine
- street twin engagement
- 4L60-E's
- Manual to auto swap
- increased line pressure to compensate for slipping clutch
- Clutch issue??
- Identifying a rear end
- Where to get Viper internals for my T-56?
- Trouble shifting 6100rpm and up.....
- interesting tranny problem
- 1993 T56 VSS vs 1994+
- Differential dilemma
- just bought a 4l60e tranny, what to look for when installing???
- 1994 Z-28 Shifting Problems With My t-56
- this rear end oil ok??
- Diagnosis?
- clutch out?
- Need 6 Speed upgrade advise.
- 3.73 on my a4 what stall
- Having a hard time shifting quickly, and need HELP ASAP!
- does anyone know what gear oil I need
- 1994 z28 camaro has a vibration in 1st and reverse
- Bad torque converter???
- 94 z28 lt1 wont shift into 3rd and shifts into 2nd at 3200 rpms.
- 4L60E to TH400 Swap questions
- 700R4 coasts while in drive after i let off of gas
- speedo gear?
- I need a clutch HELP!!!!!!!!!!!
- Tranny needs time to think.........
- Tire size options
- I broke a 1310 to 1350 conversion U-joint.
- Pic request: stock lt1 flywheel
- B&M Trans cooler installed but have a question
- Strange Rattle
- Clutch install, how difficult? Anything else I should do?
- so im rebuilding my 4L60E
- Performabuilt Stage 2 bites the dust after 16k
- changing Slave cylinder
- Anyone with a deep trans pan on a DD having scrapping issues?
- 4l60e shifting issues
- LT1 high idle with t56
- transmission upgrade
- What size bolts for converter to flexplate?
- 12 bolt rearend
- Rear End Question
- install of new gears
- New Guy needs help with clutch replacement
- 95 a4 z28 limited slip diff?
- Debating t56 swap
- 95 4L60E: Where does this part go
- Manual 6spd to auto swap???
- gotta trans issue for ya, need some help here guys!
- t56 borg warner
- trans advice
- Rearend noise
- 2001 SS Bad clutch?
- how to choose the 1st gear in a trans?
- c clip retainers wont come out????
- stall question
- m6 conversion
- 3 channel and 4 channel swaps
- how to install gears???????????
- 4L60E Question
- motive gear break-in questions?
- Rear end noise
- someone tell me what went wrong with my clutch PICS!
- Transmission Shifting Late..
- 93 z28 pro stealth ratchet install
- Knocking Under center console When Accelerating
- PerformaBuilt Limited time special offer!
- rear end building help
- crossmember bolts
- 4l60e cross fit question...
- Sloppy Shifter
- Lt-1 4l60e into a ls1 camaro ???????
- 4l60e questions
- SPEC 3+ disk in OEM PP?
- A4 shifter display not working
- Lt-1 tq converter into a ls1 4l60e
- powergrip hd pp question...
- Shifting Problem
- 3.90 Gears... Any feedback Thanks
- 97 Camaro z28 slave cylinder?
- final drive ratio 700r4?
- Transmission fluid leak
- Cant get a clutch pedal after bleeding !
- 97 4L60E lost 3rd
- 4L60E Shifting Issue
- th350 converter to lt1
- uneven wear on clutch..
- Rear end housing question.....
- may have very expensive tranny or diff issue, PLEASE HELP!
- Clutch pedal is stuck
- What transmission goe's in a 1995 automatic z28
- Won't shift from 3rd to 2nd??
- Rear end fluid leaks out when parked on a hill
- Shifting Soft
- Another noise from T56
- My 95 Camaro
- reluctor needed?
- Clutch Issues - Help Needed
- please help my camaro z28 1997 drive me crazy with 6 code
- need advice with built 93 lt1 rearend.
- Rear end differential.
- Can I run a stock replacement clutch?
- 94 PCM and a 95 4L60E
- Rebuilt T56 + New Clutch Break-In??
- Tranny acting funny
- LS1 Trans Parts
- Will there be a difference with 3.42s?
- anybody have this clutch
- Factory driveshaft differences?
- So I busted my rear end..
- 5000 rpm trans coming out of gear?
- Question about my Z28's tranny?
- rear end gears
- Got my car running but wont go into gear??
- Spohn "stock" driveshaft is 1" shorter than stock?
- Do the fittings for transmission lines have brass washers?
- Transmission goes into reverse when put in park
- Rattling noise when I go into 1st gear...
- 95 Camaro Z28 Trans issues
- will a 99, 4l60e Work in my 96 z28
- Can you fix rev limiter problem easily?
- LS1 or rebalance factory DS?
- T-56 swap?
- M6 Downshift Issue
- Transmission Fluid 4l60e
- Anyone know someone running a sell of 9" housings?
- t56 identification, maybe rare
- 95 v8 camaro; veteran assistance needed!
- Ram Street Dual Help
- Thinking out loud about my driveline/driveshaft.
- Brand new Clutch Hydraulic System Woes
- can lsd make howling noise
- Rear Diff Gasket or RTV?
- Questions concerning fuel pump and filter.
- Clutch not disengaging, slave stroke problem -- lengthen pushrod?
- T56 extension housing double or triple lip?
- Clunk!
- 4l60e question
- rear end noise? help
- Roaring in the drivetain
- So this is what my clutch and inside of tranny looked like
- Can you reuse a clutch disc?
- LT1/LS1 4L60E shifter cables... same?
- Just got my car back from shop (new slave cylinder), still having issues, please help
- 93 lt1 tranny cooler?
- Transmission question
- Estimated Cost Of M6 to Automatic Swap, & Trans Options?
- trans
- Time for a rebuild????
- what do u think about this clutch
- Gear vendor clearance issues on fbody?
- 96 LT1 new clutch vibration
- where to buy???
- t-56 removal help
- How tall is TCI 4l80E pan 278000
- Moser 9" question
- i think i confirmed it but wanted to ask a few questions
- 4l80E + OBD1 on a 96 t/a?
- No third gear in 4l60e...
- 3.73 gears???
- 2.72 - 3.73 Gear Swap 95 z28 opinions needed
- Hard to shift into 1st, 3rd, 5th, and reverse
- Narrowed 9" and upper panhard bar mount problem
- 4L60E tranny pan leaking
- Rear end q??
- Trans prob 96z28
- Can changing your auto transmissions fluid HURT it? ---
- moser 12bolt pin seal
- will a 95 camaro tranny work in a 94 trans am
- How to remove clutch, brake, and gas pedal assembly?
- not shifting right
- 1998 camaro rear help???
- T-56 stuck in Neutral- Help in Germany
- TH400, stock A4 shifter - what lever on transmission?
- stall
- wheel bearings?
- Clutch master cylinder help please.
- transmission problem
- Transmission Shop Issue
