4L60E Shifting Issue
Old Jul 8, 2011 | 01:30 PM
BushyTea's Avatar
I have a 1994 camaro with only about 10,000 miles on the rebuilt engine and GM remanu 4L60E. Also has a 2200 stall.
The past few days I have noticed mainly if I get on the gas at all then the transmission from that point has issues shifting into 1st and 4th. I get on the highway to come to work at about 65mph and the tranny wont shift so the motor is running at 3k RPM. Then once I slow down it shifts down but then it will stop at 2nd so when I go to take off it takes more gas since it isn't in 1st.
The part I have not figured out is that if I pull over, put the car into park, turn off the car then restart it then it will shift just fine again.
Thanks in advance for any help
Old Jul 8, 2011 | 06:43 PM
BushyTea's Avatar
Re: 4L60E Shifting Issue
Got home and looked for codes and it has a code 75 - Transmission system voltage low
The fuse is good, the pink wire that the manual says to check is good so not sure of the issue at this point.
Any ideas?
Old Jul 9, 2011 | 11:54 AM
SS Z28's Avatar
I had the same problem and it was the ignition switch.
Old Jul 9, 2011 | 12:19 PM
BushyTea's Avatar
Really? I guess thats good and bad. Its an easy fix but I just replaced mine about a year ago.
Old Jul 12, 2011 | 10:28 AM
BushyTea's Avatar
I just wanted to update that so far after 2-3 days of driving after I replaced the ignition switch the problem has not returned.
Old Jul 12, 2011 | 10:43 PM
SS Z28's Avatar
Glad to hear that!!
My transmission had the same symptoms as yours except that mine also wouldn't shut off with the key.
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
Snoman73
Nov 17, 2014 07:22 PM
