Transmission goes into reverse when put in park
Old Jun 15, 2011 | 06:35 PM
Z28 Owner's Avatar
When I went to park today, I noticed shifting into park caused it to go into reverse. After fiddling around a bit, it seems all the gears have shifted "up" one position. P is Reverse, R is Neutral, N is Drive, etc.
The transmission seems to be shifting just fine once in drive.
Is this likely a faulty TPS sensor, or something more expensive? If the TPS is the likely cause, what's the part number for a TPS for a 4L60E tranny?
Old Jun 15, 2011 | 06:51 PM
mrmint69's Avatar
Re: Transmission goes into reverse when put in park
My Camaro marks for drive and park are off pretty far. Its hard to tell which one is which until you get use to it. I would like to hear what the solution is.
Old Jun 15, 2011 | 07:23 PM
RamAir95TA's Avatar
Take a look under the car where the cable bolts to the side of the pan. If you hit something and broke the plastic tabs that hold the linkage to the pan it can alter the shift positions.
Old Jun 15, 2011 | 09:39 PM
Yeah, sounds like the shift cable is out of whack.
Here is some cable info.
Old Jun 16, 2011 | 01:51 PM
Z28 Owner's Avatar
Thanks for the feedback and pics. Turns out the cable had worked itself loose. Tightened everything up and we're good to go.
Sergio
Jan 27, 2016 04:27 PM
PCLZ28
Dec 24, 2015 05:19 PM
meissen
Jun 1, 2015 07:59 AM
jb4xx
Feb 2, 2015 10:00 PM
capebuf
Jan 13, 2015 07:22 PM
