How much play is normal in the rear-end
Old Oct 4, 2011 | 08:00 AM
miozub's Avatar
How much play is normal in the rear-end (2002 Z28, 10-bolt rear, truetrac differential and Richmond 3.73 gear set)? I can see about 1/4" to maybe even 3/8" of a free move on the outer diameter of the shaft. Meaning, if I put it in neutral, have the parking brake on, get under the car and make a mark on the driveshaft, I can make that mark move by 1/4"-3/8" by turning the shaft easily by hand. This should amount to 10-15 degrees of play as my driveshaft is a 3" one. I've had gears changed recently and I am wondering if they are set properly.
Thanks!
Old Oct 4, 2011 | 08:20 AM
93transam1234's Avatar
Re: How much play is normal in the rear-end
I am not an expert at all, but that sounds about right to when I have messed around with the DS before
Old Oct 4, 2011 | 08:22 AM
km9v's Avatar
As much as she'll let you.
Old Oct 4, 2011 | 08:23 AM
KWKSLVR's Avatar
S.E. Region Moderator
Yep, it definitely depends on the type of girl. Most have pretty tight tolerances as a general rule of thumb.
Old Oct 4, 2011 | 08:29 AM
Erik's Avatar
Classic Tech Moderator
Often one can get away with the rule of thumb.
Old Oct 4, 2011 | 08:38 AM
KWKSLVR's Avatar
"Rimshot!"
Old Oct 4, 2011 | 08:55 AM
calaban's Avatar
Who didn't think from the title that this thread would go down hill quick.
Old Oct 4, 2011 | 09:40 AM
KWKSLVR's Avatar
Well, this is the lounge.
Old Oct 4, 2011 | 09:47 AM
6spdpewterZ's Avatar
Old Oct 4, 2011 | 10:20 AM
True s#it there!
Old Oct 4, 2011 | 11:15 PM
miozub's Avatar
:-) ... I see that I walked right into this one ... Nicely done guys!
At least you didn't punish me for saying that "my driveshaft is a 3 inch one".
Seriously, though, If anyone knows or can check the play on his car i'd appreciate the help.
Old Oct 5, 2011 | 07:52 AM
ReNxWar's Avatar
Damnit, I was just about to do the 3" joke.
Old Oct 5, 2011 | 08:30 AM
km9v's Avatar
You may want to post your question outside of the lounge if you want a serious answer to your question. I have no idea how much play is normal.
Old Oct 5, 2011 | 08:32 AM
KWKSLVR's Avatar
Dude, they totally make prescription drugs for that now!
But yeah, one of the tech forums will probably get you better answers. You're a good sport. Good luck on finding your answer. If I knew I'd help ya!
Old Oct 5, 2011 | 08:34 AM
GrdLockV6's Avatar
I tried to play in the rear end last night... but I got zero play.
