changing Slave cylinder
Old Aug 17, 2011 | 06:51 AM
69z-28's Avatar
i need to change the slave on my 97 LT1. never done one before. looks like theres a pin at the fitting that needs to be removed but i'm not too sure. anybody change one that can tell me what needs to be done... thanks.
Old Aug 17, 2011 | 01:51 PM
96m6lt1's Avatar
Re: changing Slave cylinder
Replace as a unit......
You can replace parts on it but bleeding is a true pain so by the time you are done it has taken all day then the old part breaks next.
if you go t6o www.ws6store.com you will find the complete assembly for 168.00
Old Aug 17, 2011 | 05:52 PM
69z-28's Avatar
totally didnt answer my questions but thanks anyways...
Old Aug 17, 2011 | 07:55 PM
SC/TA's Avatar
Yes there is a pin that needs to be removed if you choose to do it that way. However as said above it is MUCH easier to change as a unit. I have done it both ways and finally had to get a mighty vac to get it bled.
Do you have a leak at the slave cyl or what is the problem?
HectorM52
Jul 30, 2017 11:46 AM
Rod Bender
May 16, 2015 02:16 PM
Briah.hood
Feb 17, 2015 02:10 PM
Jason Short
Jan 19, 2015 06:34 PM
Zone
Sep 2, 2002 07:53 PM
