no 1st gear
no 1st gear
I have a 94 Z28 that will not shift into first gear. It starts off in second and goes to 3rd and 4th fine . It just will not shift back into first even manually. Any ideas on what it could be.....
Re: no 1st gear
If it shifts into 1st with the engine off,
On level ground, put the clutch pedal to the floor and stick the engine at a few thousand rpm;
If the car moved, bleed the hydraulics;
If it stays still pull the trans. and go through it. If in the Phx area, contact me about that.
carguyshu
Jan 22, 2017 11:19 AM
Biggiebound
Apr 20, 2015 07:16 AM
