4L60 (93 Z28) Tail Shaft Question
Old Oct 3, 2011 | 08:03 AM
pearlpurple's Avatar
93 auto, (stock transmission)
Should the tail shaft output shaft move much,,, how much,,,
Mine moves approx 1/4 inch should it be rigid or should it have movement??
This is lateral movement (wobble) not end play
Old Oct 4, 2011 | 03:20 PM
jmd's Avatar
jmd
Re: 4L60 (93 Z28) Tail Shaft Question
With the slip yoke removed, it's no longer assembled and measuring lateral play is irrelevant.
The yoke and output shaft splines should be inspected, the surface of the yoke should be also and it should have nearly zero lateral play in the tailhousing bushing.
Old Oct 10, 2011 | 09:32 PM
12SCNDZ's Avatar
It will have more side to side than what should look normal.
Frank
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
