clutch out?
Old Sep 2, 2011 | 11:31 PM
jgoss350's Avatar
Unhappy clutch out?
my clutch pedal went to floor and when it came up it wont engage and when you apply pressure it squalls horrible....what do i check first?or what is it....94 lt-1 camaro
Old Sep 2, 2011 | 11:36 PM
GPZ1100's Avatar
Re: clutch out?
Check the clutch fluid.. Sounds like a busted slave cylinder.
Old Sep 7, 2011 | 12:22 PM
Hank'sZ28's Avatar
Re: clutch out?
Jgoss350,
Yup, it sounds indicative of a bad slave cylinder. If you need to replace the slave cylinder then I've posted the procedure, for your viewing pleasure
1) Disconnect the negative battery cable.
2) Raise and safely support the vehicle on jackstands.
3) Using tool J 36221 or equivalent clutch line separator, disconnect the hydraulic line from clutch actuator cylinder.
Be sure to plug the line opening to keep dirt and moisture out of the system.
4) Remove the transmission assembly. (the transmission assembly parts list can be found here)
5) Unfasten the actuator cylinder-to-transmission retaining bolts/screws, then remove the actuator cylinder from the transmission.
-To Install-
1) Position the actuator cylinder in the transmission and secure with the retaining bolts/screws. Tighten to 71 inch lbs. (8 Nm).
2) Connect the hydraulic line to the actuator. The quick-connect fitting must be pushed on, then pulled back to be sure it is properly engaged. Make sure the braided line is not twisted or kinked. The line must be kept away from other components to avoid causing damage to the line.
3) Carefully lower the vehicle.
4) Connect the negative battery cable, then properly bleed the clutch hydraulic system.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
