can lsd make howling noise
Old Jun 2, 2011 | 08:07 PM
awill12's Avatar
my rear end is making a howling noise i have checked my gears and changed all my bearings. i dont know what is making the noise? thought maybe lsd?
Old Jun 3, 2011 | 08:09 AM
Re: can lsd make howling noise
The LSD does not come into play when moving straight ahead and I don't think it would howl, anyway. Depending on when it howls, it is probably the ring/pinion.
Old Jun 3, 2011 | 10:22 AM
96 Z 28's Avatar
Have you tried changing the fluid? Mine quieted down substantially with a fluid change...
Old Jun 5, 2011 | 05:39 PM
MysticBowtie's Avatar
My money would be on your ring and pinion. I've seen that a ton of times over the years with different cars, including mine. If they get shimmed wrong and wear badly, there is no way to quiet them without replacing them and having them shimmed correctly. If a previous set of gears blew up badly, snd some metal got into the LSD, then maybe it might have problems, but normally the gears give up first.
warmeck
Mar 22, 2015 10:28 AM
Fatdog2
Feb 12, 2015 12:24 PM
warmeck
Feb 5, 2015 11:04 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
