clutch help needed
Old Oct 21, 2011 | 08:28 PM
Rij1's Avatar
clutch help needed
My clutch just went out and I'm trying to find another one and don't know if it is a 10 or 26 spline. Also would a Hays Street Performance clutch or a Centerforce Dual Friction Clutch be a decent pick?
Old Oct 22, 2011 | 10:26 AM
Re: clutch help needed
I just looked at a photo of a spare LT1 T56 that I used to own, and the input shaft definitely has more than 10 splines on it. Hard to count in the photo, it appears to be 26.
Just be sure you are looking at the unique "pull back" design required for the LT1. The Hays Street Performance LT1 clutch photo clearly shows the finer splines, indicating its a 26. But the Centerforce photo I saw showed a 10-spline clutch in the photo, but the text indicates its a 26-spline clutch. Photo must be generic. As long as you get a clutch that is specifically for the LT1, it's going to be a 26-spline unit.
Old Oct 22, 2011 | 02:37 PM
Rij1's Avatar
I'll pull it off to make sure before I get one. can I use a stock flywheel with a stage 2 clutch
Old Oct 26, 2011 | 08:02 PM
Rij1's Avatar
I just nstalled my new clutch and it good but when I push the clutch pedal down all the way it starts a tapping feeling on the pedal. Ithink the clutch fork is hitting the clutch pressure plate. is there any way to adjust how far the pedal travels or the fork?
Old Oct 26, 2011 | 08:27 PM
Rij1's Avatar
I just read through some posts that had the same problem and there solution was to grind the fork down to clear the pressure plate. Well I think another way to fix this problem is to space the release cylinder from the trans casing. it seems to work. but I would like to Know the rite way.
Old Oct 28, 2011 | 12:51 AM
Rij1's Avatar
Ttt
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Jan 30, 2015 11:08 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
