Clutch pedal is stuck
Old Jul 4, 2011 | 04:31 PM
bg1989's Avatar
Need some advice... while driving last week I pushed in the clutch to shift
at around 45mph and the pedal stayed down to the floor I couldnt even move
the shifter it was stuck in gear. I was in the middle of a major road so I tried
forcing the pedal not knowing what was goin on. Pulled over had to get it flat bed home. after inspecting the damage I damaged the push rod it was bent
so I replaced the hydraulics hoping that would do it. But the brand new pre bled from Gm would not go down the clutch pedal wont go down at all. I did not want to apply pressure to only damage the new hydraulics. Any advice
the push rod pushes into the fork right ? So something malfunctioned
Old Jul 5, 2011 | 02:43 PM
OBE1 95Z28's Avatar
Re: Clutch pedal is stuck
Need more information to help; what year/model car?
Old Jul 5, 2011 | 07:39 PM
bg1989's Avatar
I have a 96 Z28 LT1 M6
Old Aug 7, 2011 | 03:51 PM
bg1989's Avatar
Well I found the problem had to pull the tranny turns out the throwout bearing
fell apart Totally. I guess thats what the crunch sound was when i pressed the clutch. And the GM dealer wants $193.00 for a new one I dont see why
those things are so expensive. And to make matters worse I found out I have
a broken tooth on my 1year old brand new fidanza $380.00 aluminum flywheel
I tried to start the car a few months ago and heard the banging out of no where from the starter I'm gonna go back to stock flywheel. would it be a good idea to change the starter too.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
