rear end noise? help
Old May 28, 2011 | 04:55 PM
awill12's Avatar
i put 4.10 gears in my car 2 years ago every thing was right pre load the aliment of the gears every thing. any way after 1000 miles they started getting loud only when i was really light on the gas from 40 mph to 60 mph or off the gas from 35 to 0 mph the sound was a loud whin from 40 to 60 and a wha wha wha sound from 35 to 0? i changed u joints, tires, wheel bearings, and i just now put all new bearing in the whole rear end re set my gears "that still looked good" and the car sounds the same???? i think it is coming from the passenger side rear pls help very furstraded at this point
Old May 28, 2011 | 05:00 PM
Re: rear end noise? help
If they aren't set up right, they will start to whine. When you drive it like that for a couple years, you aren't going to be able to eliminate the noise. The pattern is worn in and the gears are usually ruined.
Old May 28, 2011 | 05:18 PM
awill12's Avatar
they are set up right tho. i have heard that cheap gears just whine is that true these are motive gears.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
