Rear seal question
Old Nov 8, 2011 | 03:30 PM
2manyToyz's Avatar
Rear seal question
Will be pulling the trans for a rebuild and wanted to replace the seal while i'm at it. Anything to it? Any special tools?
Manual's packed away in storage at the moment.
Old Nov 8, 2011 | 05:30 PM
mzgp5x's Avatar
Re: Rear seal question
Yes, I did it twice. Had a leak back there. I did a clutch change and pulled the flywheel. It was easy. I made a tube detail to install the seal for equal load over the seal ring. I prefer the GM seal to the Felpro seal. GM seal has more internal legs on the crankshaft.
Anyway, I solved my problem with an external vac pump drive. Problem was blowby on a FI app. No leaks @ all now.
B.
Old Nov 9, 2011 | 02:06 PM
jit11375's Avatar
someone told me to lube it before i put it on or i'd be under there doing it again pretty soon.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
