does anyone know what gear oil I need
Old Aug 28, 2011 | 10:01 PM
Rij1's Avatar
I have a 1994 camaro z28 and need to change my gear oil in my differential and need to know what I need to put in it and the additive. also what kind of posi and gear ratio do I have?
Old Aug 29, 2011 | 06:47 AM
Re: does anyone know what gear oil I need
Your owner's manual tells you the info on the gear oil. You'll need about 2 quarts (3.5 pt.). Fill to the level of the bottom of the fill hole.
Originally Posted by owner's manual
Maintenance Schedule
Section D: Recommended Fluids & Lubricants
Rear Axle (Limited- Slip Differential)
Axle Lubricant (GM Part No. 12345977) or SAE 80W-90 GL-5 Gear Lubricant, and Limited-Slip Differential) Lubricant Additive (GM Part No. 1052358 or equivalent) where required. See %u201CRear Axle%u201D in the Index.
The SPID sticker in the glove box tells you the RPO option code for the gear ratio.
Axle codes
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO (V6)
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
redz_02
Jul 24, 2002 09:42 AM
