t-56 removal help
Old May 14, 2011 | 07:58 PM
twistedbowtie's Avatar
Question t-56 removal help
i havea 95 camaro ive pulled the motor and with i pulledthe tranny with it. but now ive decided to pull the t 56. i dont have a clue when it comes to transmissions. what all do i need to remove to get the tranny out? even the little things that must be done. thanks
Old May 14, 2011 | 08:05 PM
jethrobodean's Avatar
Re: t-56 removal help
I am at a loss at what your asking..are you asking how to remove the T56 from the motor you just pulled. Or is it still in the car....
Old May 14, 2011 | 08:52 PM
the tranny is stillin the car. what do i have to unhook for it to come out?
Old May 14, 2011 | 08:57 PM
Still unclear - you pulled the motor, and pulled the tranny with it, but the tranny is still in the car?
Or are you saying that sometime in the past, you have experience pulling the motor and the trans TOGETHER, but this time, you want to pull the trans first?
Old May 15, 2011 | 06:58 AM
no ive already pulled the motor and now i wanna pull the transmission (motor is out) im wondering the steps to what i gota unhook/ unplug to get the tranny out as well
Old May 15, 2011 | 10:07 PM
OBE1 95Z28's Avatar
You'll need to remove the shifter, unplug all wiring harness to the transmission, disconnect the torque arm mount from the tail of the transmission. You can pull the transmission forward to disconnect the driveshaft; I would suggest removing the entire driveshaft first as it will make it easier to put the drivetrain back together later.
Old May 18, 2011 | 11:48 PM
thanks alott. is there anywhere that has pics and steps to doing this?
thanks again
G-BODYT56
Jan 14, 2022 11:14 PM
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
