please help my camaro z28 1997 drive me crazy with 6 code
Old Jun 26, 2011 | 07:53 AM
hassan35278's Avatar
code 1:torque converter clutch{tcc}enable solenoid control circuit.
code 2ressure control {pc}solenoid control circuit
code 30785 shift timing solenoid
code 4:cooling fan relay 1 control circuit
code 5:transmission fluid pressure{tfp}position switch circuit
code 6:torque converter clutch{tcc}pwm solenoid control circuit.
my problem that my car wont start sometime specially in the morning
tx in advance
Old Jun 26, 2011 | 10:33 AM
Re: please help my camaro z28 1997 drive me crazy with 6 code
Give the specific code numbers in "Pxxxx" format.
You do have an automatic trans, correct?
None of those codes would appear to prevent the engine from starting.
Old Jun 26, 2011 | 11:03 AM
yes mate is automatic and where i live the just quess and wondering about the problem and that cost me a lot of money and time i love this car.they say the car just have no electric pomp out 2 the injection.
plz help tx in advance
Old Jun 26, 2011 | 01:11 PM
If I'm translating this correctly, your fuel pump is not working? Is that correct? Have you used the fuel pump prime connector to bypass the computer and the fuel pump relay?
http://shbox.com/1/fuel_pump_prime.jpg
If the fuel pump runs, and produces at least 41psi when powered from the prime connector, it means you have a problem with the fuel pump relay, or the PCM (computer) is not providing the fuel pump permit signal. That could be due to the Optispark distributor having a missing low resolution pulse pattern, or the VATS system not authorizing a start. Does the "SECURITY" light flash or stay on steady when you try to start the engine?
If you want help with the codes, you're going to have to post the code numbers.
Old Jun 27, 2011 | 02:46 AM
code1.P0740
code2.P0748
code3.P0785
CODE4.P1641
code5.P1810
code6.P1860
note that my fuel pump working fine.and about the distributor i had change it 3 time in 20 days.2day my car start from the first try but dont know i notice that low oil warning coming sometime is that prevent the car from starting.the security light stay on steady
tx in advance
CamaroHeed
Mar 18, 2020 09:50 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
