Hedman headers and hedman y pipe question.
Old Sep 10, 2005 | 11:04 PM
carlo1170's Avatar
hey,
I purchased Jet hot coated hedman headers for my 87 350. the part number is 68470. They are 1 5/8 tubes and 3 inch collector. Im going to get the camaro specific hedman y pipe also. it says i can retain the stock Cat. this means the stock position correct? also, does the y pipe have a 3 inch out also??
Old Sep 10, 2005 | 11:34 PM
85_305's Avatar
Re: Hedman headers and hedman y pipe question.
Absolutely GREAT header choice man The y-pipe is actually fairly large tubing (dont remember the exact size), and when I went to match the y-pipe up to the headers it did NOT fit one bit, but hey.. I'm not the exhaust-shop right (I'm sure they will make it fit lol)
When it says it retains the stock cat, I am pretty sure it means the same location.
Old Sep 11, 2005 | 12:24 AM
carlo1170's Avatar
well it says " for use with header part number 68470 so im pretty sure it will fit. the collector is 3 inches on the headers, but they come with reducers. plus the y pipe can only be used with that header. I'm pretty positive its a 2.5 in and 2.5 out. Does anyone know what the in to the stock Cat is?? i think its 2 or 2.5, pretty sure. just need to double check.
Old Sep 11, 2005 | 06:11 AM
fratsit's Avatar
Carlo,
Dont believe everything you read. I had a set of Hedman 68470 headers and the matching "17470" Y-Pipe and it did not fit worth a crap. This was on an '84 Z28 I used to have. I had my exhaust shop recut and fab up the Y-Pipe. The outlet of the y-pipe is 2 1/2 inches.
I also had bolt hole alignment issues with the headers themselves.
If yours fits....then right on....just expect the unexpected.
Good luck.
Frat
Old Sep 11, 2005 | 09:29 PM
85_305's Avatar
Originally Posted by fratsit
Carlo,
Frat
Really? That's exactly what looks like is gonna happen on my 305 I am gonna be pissed if they dont fit right
Old Sep 12, 2005 | 04:39 PM
fratsit's Avatar
Yeah Brother....
It did not fit at all. The problem was with the driver side of the y mating to the driver side collector. Did not come anywhere close. Now this was back in 1994 on an RHS Performance engines built 355, however, it still should have fit.
My muffler shop had to cut and re-fab.
I'll lend an ear if ya need to vent in case is does not fit.......
Frat
Old Sep 13, 2005 | 12:13 AM
85_305's Avatar
Frat
Hehe thanks Frat
But I was holding the pipe up to the headers, and for the LIFE of me could NOT figure out how in the hell it was going to mount
Old Sep 13, 2005 | 01:02 PM
Rice Killer87's Avatar
Sounds like to me yall are trying to put this y-pipe onto headers that are firmly bolted to the engine. Sometimes you need to keep all the bolts loose until you have ALL of them started before you tightening them. That will give each header a little bit of movement...sometimes just enough for the y-pipe to bolt up...sometime not
Good Luck
Old Sep 13, 2005 | 01:10 PM
85_305's Avatar
What I mean is the y-pipe is really straight. There is NO WAY a straight piece of steel is going to fit up in the car to a pair of shorties. The only way for the y-pipe to even *touch* the headers is to hold them straight up and down
Old Sep 13, 2005 | 04:48 PM
fratsit's Avatar
Thats exactly what happened to me, on the drivers side. Did not even come close.
Frat
Old Sep 13, 2005 | 04:51 PM
fratsit's Avatar
Good Luck
Yep.....I had all the header bolts loose to the point that the bolts almost fell out. I was a beginner back then (although I am no expert now ) and started out with the header tight......
Frat
Old Sep 13, 2005 | 11:39 PM
85_305's Avatar
Frat
Oh
Old Sep 14, 2005 | 07:39 PM
fratsit's Avatar
Any luck??
Old Sep 16, 2005 | 12:09 AM
85_305's Avatar
Me? I'm not gonna dick w/ it, I will leave that up to the exhaust shop next summer
racecarz28
Mar 30, 2015 09:55 PM
NED4SPD
Sep 16, 2002 10:45 PM
chesee48
Aug 22, 2002 08:28 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
naaz90
Jul 27, 2002 08:22 AM
