Ignition Coil
Ignition Coil
do you guys have any input on which coil I should buy? which ones have you had good or bad experiences with...i need a new one, just not sure which to get...everybody said that had the MSD said they hated it and they only lasted like 8 months..
Re: Ignition Coil
can't find them...just found the package deal again...and that looks like an hei coil...i need a remote mounted...
could somebody show me a part number or link for just the coil? or does accel make any other good coils?
Re: Ignition Coil
www.jegs.com
http://www.jegs.com/cgi-bin/ncommerc...61&cgrfnbr=883
Flame Thrower 50,000 Volt Coil (Petronix...very good)
#751-D3000 Street/Strip HEI Coil; Red/Yellow Wire 0.50 ohm $39.99
#751-D3001 Street/Strip HEI Coil, Red/White Wire, 0.50 ohm $39.99
#110-140003 HEI Super Coil with Red and Yellow primary wire. Fits Chevy 90° V6 & most V8, and Cadillac V8. | View Product $51.99
#110-140005 HEI Super Coil with Red and White primary wire. Fits Buick V6 and V8, Oldsmobile V8, Pontiac V8 and 1981-91 Corvette | View Product $51.99
Yours looked like a Coil-in-cap, from the pictures, not sure if a 300+ is available but these will do a Great Job!...
Re: Ignition Coil
nope mine is remote mounted, had to switch becuase of the HSR...so no more HEI...what about the pertronic xtreme 60,000? also which ohm of ristance should I be looking for?
thankyou for the compliment...its still a work in progress...
Re: Ignition Coil
http://www.jegs.com/cgi-bin/ncommerc...83&prmenbr=361
or
http://www.jegs.com/cgi-bin/ncommerc...40&prmenbr=361
or if you could use the other type this kit is the bomb!...
http://www.jegs.com/cgi-bin/ncommerc...14&prmenbr=361
A performance module will do more for your ignition than a hot coil, by increasing dwell time and decreasing recharging time. Accel modules:
http://www.jegs.com/cgi-bin/ncommerc...91&prmenbr=361
or
Re: Ignition Coil
alright thanks...accel sounds like the way to go...what is that last product you listed there? i've never seen one...what does it do and where does it go? also which one would I need to run it on my car? i'm thinking I need one of the 8 pin ones..
Re: Ignition Coil
Since you switched to a remote mount distributor, you'll need the 8 pin, but I'm not sure how you will wire up this distributor to work correctly w/o the right harness, but I'm sure if you researched it, it can be done..
Oh, it's what the harness plugs into at the distributor, remove the cap, you'll see it's screwed down to the base and the pick-up coil wires are connected to it inside the distributor.
