Inside Temperature Gauge Post - Rumor or Real??
Old Oct 7, 2005 | 12:39 AM
Castro's Avatar
Angry Inside Temperature Gauge Post - Rumor or Real??
Hey I found this wanted to hear if anyone else had come across this:
Chevrolet had a bulletin for camaros with temp guages being out of
calibration as well as I can remember you get a 10 ohm 1/2 watt resistor and cut the wire going to the coolant temp SENDER and splice the resistor in there this is supposed to bring the guage reading down to match the actual temp of the coolant
NOTE: Be sure you have the temp sender and not the sensor as 10 extra ohms there would certainly cause performance problems
http://www.autoforumz.com/-Temperatu...pict35298.html
Old Oct 7, 2005 | 06:11 PM
92blue's Avatar
Re: Inside Temperature Gauge Post - Rumor or Real??
That link says the bulletin is for 93-94 models with specific vins. That does not relate to Thirdgens. Not sure if you caught that or not.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
