valve guides
Re: valve guides
Just need air and a spring compressor. Be sure that they air supply isn't lost when doimg so or you will be chasing a valve. That bites by the way especially when on the last valve. Seems it brings new meaning to a dropped valve lol.
Re: valve guides
Originally Posted by knta4dnu
Or you can stuff rope through the spark plug hole until you fill the cylinder enough to hold the valves up. Worked for me.
oooh, very creative, i like
Re: valve guides
If you do the "rope trick", pull all the plugs so you can turn the motor over by hand. Stuff as much rope in as you can, then turn the motor till you feel the resistance of the piston pushing on the rope. Now you know the valves are pushed up snug.
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
gelbza
Jul 12, 2015 08:10 AM
