A good ammount of CFM for a cooling system?
Old Sep 9, 2005 | 11:59 AM
85_305's Avatar
Ok.. what would be a good ammount of cfm for a fan cooling system on a 305? What does the stock push?
Thanks all,
Matt
Old Sep 9, 2005 | 06:23 PM
Kwiksilverz28's Avatar
Re: A good ammount of CFM for a cooling system?
I tried some fans to cool mine, but ended up with the BeCool duals and should have just started there to begin with....
Old Sep 10, 2005 | 10:16 PM
85_305's Avatar
How many cfm are they pushing though?
Old Sep 11, 2005 | 11:50 AM
2780 cfm part # BCI-75007 at www.summitracing.com
Old Sep 11, 2005 | 09:33 PM
85_305's Avatar
Good deal man
Will I need to order that other crap below it, or will the stock fan-mounting hardware be sufficient?
Old Sep 11, 2005 | 10:37 PM
I have a BeCool radiator too, and at like $600, I was not about to shove anything through it. Just a thought...... I got the aluminum brackets....
Old Sep 12, 2005 | 10:22 AM
85_305's Avatar
Will I need to upgrade from a stock radiator in order for that listed kit to work???
Old Sep 12, 2005 | 05:14 PM
Zepher's Avatar
I am running the stock dual fans on my car with a 160stat and the ECM programmed for that stat and it stays at around 160-180 all the time. It did go to 200 one hot afternoon while I was auto-x'ing but that is expected since I was at 5K rpms for most of the course.
Old Sep 13, 2005 | 12:21 AM
85_305's Avatar
^See I need to rid my car of that crappy mechanical fan. For more reasons than one, one being I can't use my dual-snorkel intake w/out the elec. fans
Old Sep 13, 2005 | 12:31 AM
iansane's Avatar
I don't understand spending so much on cooling. My car with a 180* stat, and a lower temp fan switch/lower temps in the bin and my car is rock solid at 180 once it warms up. In traffic, at stoplights, on the freeway, heavy abuse, everything.
Old Sep 13, 2005 | 07:13 AM
I wish. With BeCool radiator, dual fans, Flowkooler water pump, 160 thermostat, and it still runs 190-200 down the expressway. In the winter it is fine, but when the temp is 92, the humidity heading above 50%, and the A/C cranked, it is pushing it to the limit. Lose the heat, humidity, or A/C, and it would be a different story....
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
