cooling fans won't come on?
Old Sep 3, 2005 | 06:52 PM
LoudmouthSS's Avatar
When i first got the car it had a 160 degree thermo, 176 degree on/166 degree off fan switch and when i rebuilt the engine and put everything back together, the fans wouldnt come on and the car was running really rich. So i decided to stick all the stock crap back in...195 thermo and a w/e fan switch (idk what it is)...neway the fans dont kick in at all. Any suggestions?
Old Sep 3, 2005 | 09:23 PM
sparafucile17's Avatar
Re: cooling fans won't come on?
I'm not 100% sure but I think there should be a relay that actually turns on the fan when the ecm tells it too. Find the relay and test it to make sure it still works. If you don't know how to do this, here's a quick way... Find out what relay pins connect to the coil. There should only be two. Connect one side to ground and the other side to +12v. When the circuit is complete you should hear it click. No click, then it's bad. If it does click then you may want to check the wiring running to the relay for shorts.
Old Sep 3, 2005 | 09:58 PM
Iroc313's Avatar
my brother's fans weren't coming on so he replaced the fan motor and found out that the battery acid had eaten away the ground wire for the fan's, just thought I'd help lemme know how it works out
Old Sep 4, 2005 | 10:03 AM
I know the ground is good. And i think my dad tested the wires...he said they were good. Im gunna rig a switch to them today and see what happens
Old Sep 4, 2005 | 11:23 PM
quickchicken's Avatar
loudmouth, check your knock sensor plug and your fan switch plugs. reverse them. the 2 plugs are identical and are easily swapped.
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
