Smoke when started
Old Nov 8, 2005 | 10:19 PM
ChevyRacer87's Avatar
Question Smoke when started
When i start my Iroc-Z28 350 TPI the L98 a cloud of smoke comes out the tail pipes, i was told it was the valve guide seals, what can i do to fix this without having to pay $500
Old Nov 9, 2005 | 06:44 AM
91-Z28-L98's Avatar
Re: Smoke when started
The only way to fix it without paying the $500 is to replace the seals yourself. Don't try any of those Smoke-B-Gone products because they will not work. This is a common problem amongst SBC engines. Most people just ignore it until they need to remove the heads for some reason.
Old Nov 9, 2005 | 09:40 AM
jayman350's Avatar
yeah thats definitely the seals. Its actually not that bad to do if you have access to compressed air. You'll probably need to take off your headers or manifolds to really be able to get access to the plug holes.
You'll need a fitting to thread into the spark plug hole to put the compressed air into the cylinder to keep the valve from falling onto the piston (thats when you would have to take the heads off) Then you remove the valve spring and retainers, take off the old seal, replace it with a new one, put spring and retainer back on. I would suggest doing both intake and exhaust for each cylinder before you move to the next one.
Fel-pro makes a set that come with nylon caps to put over the actual seal and they work really well. I don't remember the p/n though, too long ago.
hope this helps, i would always like to see someone fix their own car rather than get screwed by someone
Old Nov 12, 2005 | 04:23 PM
LesPaulGoth's Avatar
I thought I read somewhere that you can tie a string to the valve somehow to keep it from falling in?
Old Nov 13, 2005 | 01:33 AM
CamaroSS30thAnn's Avatar
valve guides.... they are easy to replace , the only hard part is getting teh head off, good luck
Old Nov 13, 2005 | 09:55 AM
Dave89IROC's Avatar
why???? there is absolutely no need to pull the head?
Old Nov 13, 2005 | 04:16 PM
yeah i just realized im adumbass and was thinking of other things at the time
EDIT: u dont need to pull the heads lol
Old Nov 13, 2005 | 04:31 PM
Talking Re: Smoke when started
so it wont hurt the car if i dont do it right away?
thanks for ur help much appreciated
Old Nov 13, 2005 | 06:50 PM
Dave89IROC's Avatar
as long as it gets driven pretty good everytime it is started, it won't hurt a thing(unless you still have the cat.......)
Old Nov 13, 2005 | 07:01 PM
IROC-T's Avatar
You might be thinking of a piece of clothsline rope shoved into the sparkplug hole and bring the piston up,this works great. I've seen people use a rubber band around the stem,but this can be tricky.
Old Nov 13, 2005 | 07:11 PM
Dave89IROC's Avatar
hell, I've done it just by bringing the piston up to TDC, the valve will drop about 1/2-3/4 inch, then stop, and if you use any of the seals that go around the stem and guide, the new seal will hold the valve up when you put it back together
Old Nov 13, 2005 | 08:54 PM
Tom87IROC's Avatar
I had my valve seals replaced but mine stills puffs on some starts. Not quite as much as it used to, but I thought this would eliminate the puff all together. Any other suggestions?
Old Nov 15, 2005 | 02:30 PM
cat????
Old Nov 15, 2005 | 02:43 PM
Dave89IROC's Avatar
cat????
catalytic convertor
Old Nov 15, 2005 | 04:56 PM
how detremental can that be to your catalytic converter?
