Hesitation when I first push down on the pedal
Old Oct 30, 2005 | 10:32 PM
staleyracing's Avatar
Unhappy Hesitation when I first push down on the pedal
I was wondering if anyone had any ideas on some things to check on. The problem is when I push down on the accel. pedal the car hesitates then goes. It doesnt do it all the time or in reverse. If anyone has any ideas I would be very thankful
Josh
Old Oct 31, 2005 | 09:19 AM
85_305's Avatar
Re: Hesitation when I first push down on the pedal
Try using some carb-cleaner. Have somebody spray it as your pushing down the accelerator.
Old Oct 31, 2005 | 10:18 AM
IrocManiac's Avatar
Is this a carbed or TPI car?
You might also check for exhaust restrictions, is there a noticable power drop the higher you rev it?
Old Oct 31, 2005 | 07:46 PM
Arrow Re: Hesitation when I first push down on the pedal
Its a TPI car. I know the TPS, Idle sensor, Oxy. Sensor,Fuel Filter, Fuel Pump, Plugs, wires, cap, rotor...have all been changed. Tomorrow Im gonna clean out the throttle body.
Old Nov 1, 2005 | 06:08 AM
85_305's Avatar
^Sounds like your on track
Old Nov 1, 2005 | 08:54 AM
91-Z28-L98's Avatar
This sounds like a slight disagreement between sensors. If it was a MAF equiped car I would say it is probably due to an air leak after the MAF sensor. On MAP cars this effect is not as noticable, but still present. So make sure you look for vaccuum leaks.
Ericksd
Jan 20, 2016 06:07 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
