need help with tranny??
Old Aug 27, 2005 | 12:03 AM
1986camaroz28's Avatar
Question need help with tranny??
I Have A 1986 Z28, It Was Originally A 305 4bbl Car With A 5sp Tranny.
I Yankked The 305 And Replaced With A 383 Stroker. I Have To Use A Sbc 400 Flywheel Because The Engine Is Externally Balanced. I Want To Use The Factory 5sp, What Clutch, Pressure Plate Setup Do I Use? The Original Pressure Plate From The 305 Doesn't Come Close To Fitting The Flywheel From The 400. Is All This Going To Fit Inside The Bell Housing?? Thanks In Advance For The Help
Old Aug 27, 2005 | 01:47 AM
iansane's Avatar
Re: need help with tranny??
Need more info. Where'd you get the flywheel? How big is it?
You're most likely going to have to use a conglomoration or some really expensive parts.
Old Aug 27, 2005 | 09:56 AM
got the flywheel from stevens specialty engine parts,it measures 14" across. looks like my factory clutch disc will fit, just need help getting the correct pressure plate
Old Aug 28, 2005 | 10:09 AM
NastyTA's Avatar
You should be able to use a standard flywheel since they're neutrally balanced. The motor should be external front and internal rear which is why you have to use a 400 balancer.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
