Replacing a stud..... how hard is it?
Old Nov 12, 2005 | 10:58 PM
'86 350's Avatar
Hey, I've got a stripped stuf on my 3rd gen and I need to replace it. It's a 10 bolt disc brake rear end. How hard is this going to be and what tools will I need? About how long will it take?
Thanks, Brandon
Old Nov 12, 2005 | 11:20 PM
LesPaulGoth's Avatar
Re: Replacing a stud..... how hard is it?
Eh, I had the same thing happen to me on my exhaust manifold. I hobbled her to my buddies shop and his dad tore it out with an air hammer - I believe thats what it was.
Old Nov 13, 2005 | 02:17 PM
'86 350's Avatar
Hmm.... anyone know if I can do a wheel stud with basic tools lieka hammer and stuff? What do I actually need to do to get it out?
Old Nov 13, 2005 | 05:57 PM
95Cam86Roc's Avatar
I just recently done this to two studs on my car. It was the front passenger wheel though. I'd assume that is going to be basically the same to do the rear. I thought it was rather easy and i never work on my car or anyone elses. Of course you will need to take the wheel off, then the brake caliper, the take off the grease cap, pull the pin out of the nut, then unbolt the nut and slid the rotor off. All i did was lay it on the ground with the studs up and nocked them out with a hammer and then hammered them in from the backside. Then you just put it all back together like how it came off. The only tools that i had was a hammer, allen wrenches for the bolts of the caliper and a wrench for the bolt in the grease pit. I hope this helps you. It really isn't hard if i can do it.
Old Nov 13, 2005 | 06:48 PM
Dave89IROC's Avatar
on the rear, jack it up, pull the wheel, pull the caliper, slide the rotor off, then take a hammer and hit the bad stud, bigger the hammer and better the swing, the quicker it will come out, but it will come out, then put the new stud in from the rear, slide a few washers over the new stud, take a cheap type lugnut and put it on the stud with the flat side against the washers, just tighten it down, it will pull the stud in, stop when the stud seats, and then reinstall everything
Old Nov 13, 2005 | 08:55 PM
'86 350's Avatar
Allright, I'm assuming I need to pull apart the rear drum brakes to do this right? Otherwise it's the same?
Old Nov 14, 2005 | 02:36 AM
Dave89IROC's Avatar
drom brakes? you said disk brake rear end? if drum, just pull the wheel and the drum, them you can do it
Old Nov 14, 2005 | 02:52 PM
'86 350's Avatar
Wow, my mistake. I don't know why I wrote disc, but it appears I did. Allright thanks for your help guys, I'll probably get to it sometime this week.
Old Nov 24, 2005 | 07:52 AM
Crovax WS-6's Avatar
yeah its wicked easy. i broke one of the front ones off of my car. took me 5 minutes to change it. of course i did have the help of an air hammer that got the sucker out in like 3 seconds flat. lol.
Old Nov 25, 2005 | 10:06 AM
'86 350's Avatar
Yeah, I did it about a week ago. It was really easy. 4-5 wacks with a hammer and that thing poppped right out. Simply pulled the new one through with a lugnut and it was set to go.
silvermansteve
Mar 4, 2015 05:02 PM
grabbem88
Feb 17, 2015 07:49 AM
rjc1629
Jan 27, 2015 10:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
CobraEatr
Jul 29, 2002 11:46 AM
