LT1 guy needs help with buddies TPI setup
Old Oct 14, 2005 | 06:59 PM
1BadBrd's Avatar
Helping a friend put together his TPI and there are somethings i just don't know.
First off we are deleting his A/C and all smog equipment. I don't know how to setup his pulley system without reinstalling the smog equipment and deleting the A/C.
Also he wants to put the LT1 intake onto his engine but i don't know all what he needs to do to make that happen. I looked at LT1intake.com and his setup is great but its $400 for the intake to be modded and another $100 for the fuel lines and another $65 for the thermostat housing. So the deal really isn't that great. Is there another way to put a better intake then stock?
Old Oct 14, 2005 | 08:04 PM
Dyosis's Avatar
Re: LT1 guy needs help with buddies TPI setup
I would suggest a Holley Stealth ram but those run about the same as a converted LT1 intake. Get a set of used aftermarket runners off of ebay(or where ever) and port the plenum and the base.
check out thirdgen.org for tons of info on TPI motors.
Old Oct 14, 2005 | 09:04 PM
Damon's Avatar
There is a guy over on Thirgen.org who did both A/C and smog delete without buying the 1-LE A/C delete pulley that is normally necessary to do this. I think he posted in the TPI section about that over there.
The Reader's Digest version: He removed both and installed a parts store idler pulley of the same diameter on the stock tensioner arm but a ribbed style one (to lay the inside face of the serp. belt on) and then used a modified belt routing with a different length belt. It looked pretty slick and claimed it worked jsut fine.
If you just want to delete the smog pump you just need a 96.5" belt and a modified belt routing (covered in a tech article on that website).
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
CaRParts102
Dec 6, 2014 08:45 AM
Red97LT1
Aug 7, 2002 05:45 PM
