jumping timing?
Re: jumping timing?
Yup that happened to me too, and I also suspected the timing chain. But iansane is right, its the EST (or I thought ESC?) wire. When the wire is connected the ECM will advance or retard the timing on the fly which can mess you up when you check timing or try to reset it. Disconnect the wire and you should be good to go.
Re: jumping timing?
Pull the distributor and replace the broken roll pin holding the cam gear. It sounds like the gear is spinning on the shaft but there's just enough force to hold it in place for a while.
Oncomingstorm22
Jan 22, 2015 07:15 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
