!smog pump, !ac, stock tensioner.
Old Aug 26, 2005 | 09:16 AM
Narcah's Avatar
Not sure if anyone has done this or not, but I managed to remove the smog pump and ac compressor (along with their 50 lbs and unknown rolling resistance) from my 89 l98. It takes a shorter serptantine, but it does work. the only snag is the return hose to the radiator rubs on the belt. I'm still looking for an elegant solution, but I have it working now.
The good news is, the only place where the serpantine does not match the pulley (rib to rib, smooth to smooth) is on the tensioner.
I'm hoping for high 13's.
Old Aug 26, 2005 | 09:46 AM
bmillington's Avatar
Re: !smog pump, !ac, stock tensioner.
If you have to go through the trouble of designing a new tensioner, you might want to think about moving your Alt. down to where the smog was. You would have to make a bracket but then you would have more room up top. Just a idea
Old Aug 26, 2005 | 10:03 AM
Runin2Nite's Avatar
y dont u just buy an ac delete pulley???
Old Aug 26, 2005 | 10:30 AM
gixxer92's Avatar
Here is what I did on my IROC.
http://gixxer92.eifba.net/temp/garag.../LT1-L98-3.jpg
Old Aug 26, 2005 | 12:09 PM
raul.garcia's Avatar
Ribbed Tensioner; Autozone, by CompressorWorks. Part number 45971
I haven't bought it, the info is second hand.
Old Aug 26, 2005 | 05:44 PM
Dave89IROC's Avatar
Originally Posted by gixxer92
hmmm..........LT1 bracket.........
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
alphaauto
Jan 23, 2015 07:42 AM
