Trying to hook up an msd 6a???
Old Sep 17, 2005 | 12:38 PM
Runin2Nite's Avatar
i'm mounting it under the dash on the passenger side unless i find a new spot under the hood. i can't figure out where to hook up a few wires. theres a harness on the back with 2 wirespurple and green- to the MAG PICKUP in distributer or crank trigger. OR i can use a white wire -tp the points or amplifier output (connecects to yellow wire of timing accessories)
i can't find either
also the large red wire says hook to 12v switched.... so does that mean i need to get a switch to engauge the box????
sorry if these questions are stupid.. i jus don't want to blow somthing else
Old Sep 17, 2005 | 12:45 PM
fratsit's Avatar
Re: Trying to hook up an msd 6a???
Go to www.msdignition.com
I was just there and found the directions on wiring an MSD-6a. Its in .PDF format so you will need Adobe Acrobat Reader.
Remember.....the only stupid question is the one not asked.
I mounted my 6BTM in the same location. Remember to tell your passengers to not "kick the spark box" as I say.
Good luck with it.
Frat
Old Sep 17, 2005 | 04:07 PM
Rice Killer87's Avatar
Switched 12V is just power when the key is turned in the "on" position. And I'm pretty sure you dont need an inline fuse because the box has in internal one. It was like that when I helped a buddy put it on his '70 Nova...Check the destructions just to be sure.
Have Fun
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
