HELP, bad idle, hesitation
Old Nov 1, 2005 | 03:18 PM
staleyracing's Avatar
Unhappy HELP, fast idle, hesitation
My idle will speed up after a hesitation. It will goto between 1500-2000rpms when in park. Its like a serge, it will dip down and then idle up. Ive cleaned the TPI (throttle body), changed the TPS, Ox. Sensor, Plugs and wires, cap and rotor. and I cant find any vacuum leaks anywhere. All the hoses are in good shape. I put in a new fuel filter. To top it off there isnt a SES light code so im open for new ideas. Thanks
josh
Old Nov 1, 2005 | 04:33 PM
91-Z28-L98's Avatar
Re: HELP, bad idle, hesitation
Check timing.
Old Nov 2, 2005 | 12:14 AM
V8Rumble's Avatar
I'm guessing that you'll probably want to take a look at your IAC. Adjusting it is pretty easy.
Good luck, let us know how it works out.
jocamino
May 14, 2015 07:37 AM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 08:49 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
