need ur guys help
Old Oct 16, 2005 | 05:09 PM
bowtiewounders's Avatar
need ur guys help
do u think i should swap my 350 tbi moter for a l98 tpi motor in my 1993 chevy k1500 pickup truck
Old Oct 16, 2005 | 05:41 PM
91-Z28-L98's Avatar
Re: need ur guys help
I don't know too much about the truck, but in a 3rd gen swapping from a TBI to TPI is just about as hard as an LT1 swap. You already have a 350, so I personally would either go carbed or just upgrade the TBI unit.
Old Oct 16, 2005 | 06:16 PM
thanks would a lt1 be worthit
Old Oct 16, 2005 | 07:21 PM
83_z_fan's Avatar
Originally Posted by bowtiewounders
do u think i should swap my 350 tbi motor for a l98 tpi motor in my 1993 chevy k1500 pickup truck
First off why would you want to just to gain the tpi? If so then no and as far as that goes I'd carb it before I tpi-ed it. Gains are minimal form a good carb tune to tpi. Plus a carb has less crap to deal with.
Old Oct 16, 2005 | 08:02 PM
90rocz's Avatar
You'd need to have the PROM from the TPI doner, and wire the injector harness to the wires going to your TBI. Then you'd need a high pressure fuel pump, since TBI is @ 14psi and TPI is @ 43-45psi. And replumb your fuel feed and return lines to match the TPI fuel rails, just from say the fuel filter to the motor.
Wouldn't be hard, if you take your time and get wiring diagrams etc.
The TPI would boost the low end torque for the truck, plus add some ponies, and since fuel is being injected right into the head port, it won't puddle under the TBI and should gain some mpg.
Old Oct 17, 2005 | 04:20 PM
se i got 3 years to finish my truck so if i do somethin i want to do it the way i want to basiccly but if the majority so dont then i wont but i might buy a ls1 or somethin like that
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
