Electrical or mechanical gauges
Hi, I'm about to order some gauges for my car, and without pulling the gauge cluster out, I was wondering if you guys could tell me if the gauges in our cars (mine's origianlly an '86 2.8 Camaro) are electrical, mechanical, or a mix of both?
Also, I recently got a 8 cylinder tach out of a junkyard for my car, becasue I had the original 6 cylinder tach in there and it was reading off becasue of the 350 that's now in the car. However it still seems to read about the same. The other day, according to my tach, I my engine up to about 8,000 rpms in first gear when I was driving the car real hard. Well, I know that's not right, because I've never seen a 350 actually wind out that high (this is just basically a high perforamnce, street 350) and second of all, there's no sign of the engine being over revved. (bent pushrods, etc.)
So I was wondering, is there a gear I need to change or something to get the tach to read correctly. Does the distributor gear need to be changed or what?
Thanks for any help you can give, Brandon
Re: Electrical or mechanical gauges
The 6 cylinder tach will be calibrated to see more pulses per second than the V8's. You'll either need a V8 tach or find some way to get the V6 tach recalibrated for a V8.
All aftermarket tachs have a 4-6-8 setting on them depending on how many cylinders the engine is.
if your buyin new stuff i would recemand electric not mech. just personal experence. good luck the the ride
99TransAmWS6
02-12-2015 07:23 PM
